John B. Parker
#1 Posted : Thursday, October 2, 2014 8:15:15 AM(UTC)
John B. Parker
Unit simply stopped working one day, and does not respond all. It is as if the GFI or circuit breaker tripped, but they did not.
#2 Posted : Friday, October 3, 2014 12:19:16 AM(UTC)
Parts for GE SMR04DASACS Refrigerator - AppliancePartsPros.com
Have you checked the power at the wall receptacle?
If not I would do that.
Next check for the 120 volts at the machine end on the power cord.
If OK
Unplug the unit and the two wires at the control thermostat.
Check across the thermostat with a meter, should be 0 ohms.
OR
Short the two wires together.
You may have to tape them so they do not short to anything else.
Now plug the unit in to see what happens.
If it starts up you need a new control thermostat.
John B. Parker
#3 Posted : Friday, October 3, 2014 8:12:52 AM(UTC)
John B. Parker
Originally Posted by: denman Go to Quoted Post
If OK
OR
Thank you so much. I shorted the control switch wires, as suggested, and it worked. Is this a part from you, or or is it easily sourced at the local GE or hardware store?
The power to the original switch (white wire) is hard wired. Is this a job for a simple connector?
#4 Posted : Friday, October 3, 2014 10:41:31 AM(UTC)
I cannot say.
Would be best to talk to a parts representative, they have more info and expertise than I have.
Guest (4)
