turbo808
#1 Posted : Thursday, September 25, 2014 6:18:38 PM(UTC)
turbo808
Replaced control panel face. Worked couple weeks fine. Then started acting up again. Put new $280 part in today. Range works fine again. Oven can not turn off yet. There another part need to fix this ? Thanks .
turbo808
#2 Posted : Friday, September 26, 2014 6:06:03 PM(UTC)
turbo808
Bump. No clues . Post more info if need .
Whirlpool Oven stays on (Oven Repair (including Ranges and Cooktops))
by helphotoven 3/19/2012 6:03:43 AM(UTC)
Oven Stays On... (Oven Repair (including Ranges and Cooktops))
by aad 8/9/2010 11:48:06 AM(UTC)
by Hickstreme 9/15/2009 1:05:19 PM(UTC)
XL44 Oven stays on (Oven Repair (including Ranges and Cooktops))
by coyote_ptm 7/16/2009 6:16:41 PM(UTC)
GE Oven Stays On; Wierd voltages (Oven Repair (including Ranges and Cooktops))
by jedflight 7/13/2009 8:12:40 AM(UTC)
Oven stays on- no temperature adjustment (Oven Repair (including Ranges and Cooktops))
by whtent 4/19/2009 12:27:15 PM(UTC)
oven stays on with switch in off position (Oven Repair (including Ranges and Cooktops))
by jmann639 4/12/2009 6:24:06 AM(UTC)
oven stays on after turning off (Oven Repair (including Ranges and Cooktops))
by bfawcett 3/29/2009 4:42:33 PM(UTC)
jenn-air oven stays on (Oven Repair (including Ranges and Cooktops))
by Keith hedrick 1/28/2009 4:42:14 PM(UTC)
kenmore electric range pf code and top element in oven stays on always (Oven Repair (including Ranges and Cooktops))
by closs2sx 1/6/2009 5:32:12 AM(UTC)
Oven stays on with switch on the off position (Oven Repair (including Ranges and Cooktops))
by ivan coulombe 11/27/2007 10:58:01 AM(UTC)
