3 Pages<123
davejiu
#21 Posted : Thursday, September 25, 2014 6:31:47 AM(UTC)
davejiu
Originally Posted by: fairbank56 Go to Quoted Post
Use a hammer and putty knife and work the knife into the groove between the pulley hub and cam hub. Once you get a gap between them, use a flatblade screwdriver and pry up with that.
Eric
Eric -
When putting the cam hub back on I can not seem to get it to stay on, it wants to fall off. Does it require pressure (via clamps) to put back on in order to stay put?
Thanks,
Dave
fairbank56
#22 Posted : Thursday, September 25, 2014 10:19:37 AM(UTC)
fairbank56
Groups: Expert
The pulley hub, pulley and pulley nut holds everything together.
Eric
davejiu
#23 Posted : Thursday, September 25, 2014 10:24:22 AM(UTC)
davejiu
Eric -
Thanks so much for all your help. Putting it all back together. Couldn't of done it without your insight. Very much appreciated.
Thanks,
Dave
3 Pages<123
