gtg932
#1 Posted : 11 years ago
gtg932
Hello,
My Maytag washer is leaking oil onto the floor. Is there an easy way to fix this? I found a video on Youtube (https://www.youtube.com/watch?v=mz1aDPYey8o) that shows how to change the seal. If the seal is the problem, it doesn't look too difficult to repair.
sidfink43
#2 Posted : 11 years ago
sidfink43
Yep, go ahead and replace the seal, fill it with the appropriate level of oil and you should be all set.
gtg932
#3 Posted : 11 years ago
gtg932
Thanks for the reply. Do you know what kind of oil this machine uses, and how much?
sidfink43
#4 Posted : 11 years ago
sidfink43
I don't have the specs on that model, so I suggest you contact the parts department of APP (those of us who reply here are volunteers and do not work for APP) or contact customer service at Maytag and they should be able to give you that information.
fairbank56
#5 Posted : 11 years ago
fairbank56
Groups: Expert
You need to determine where the oil is leaking from. It could be the input shaft seal, the cover gasket or the seals at the spin pinion gear that protrudes out the top of the gearcase. If it's a small amount of oil, I wouldn't worry about adding more back in. If it's a lot, then the only way to get the correct amount in would be to remove the top cover. Oil level should be just below the top edge of the lower half of the gearcase. This washer has the Maytag name on it but it's made by Whirlpool. The correct oil to add is at this link.
Whirlpool 350572 Gear Case Oil - AppliancePartsPros.com
Eric
gtg932
#6 Posted : 11 years ago
gtg932
I took the cover off the washer and noticed the oil is dripping from a different part than what the video shows. Here are pics of the part:
UserPostedImage
UserPostedImage
fairbank56
#7 Posted : 11 years ago
fairbank56
Groups: Expert
You need to determine exactly where the oil is leaking from. Just because it's dripping off the bottom most part of the transmission, doesn't mean that's where the leak is. It could very well be the input shaft seal and the oil is running along the transmission housing and accumulating there at the most bottom part and dripping off.
Eric
gtg932
#8 Posted : 11 years ago
gtg932
I've never taken this part of the machine apart before so I'm not sure how to dig further in to see where the oil is coming from. Are there any videos that would help with this area?
UserPostedImage
UserPostedImage
fairbank56
#9 Posted : 11 years ago
fairbank56
Groups: Expert
It's leaking from the input shaft seal and just running along the bottom of the transmission and dripping from the lowest point. Your first diagnosis was correct. Just replace the input shaft seal. Unlikely that you've lost enough oil to worry about replacing any.
Eric
