richardbecker
#1 Posted : Sunday, September 21, 2014 6:34:47 AM(UTC)
richardbecker
long story short, movers broke the timer switch dial off- i repaired by drilling shaft pieces and screwing together. Meanwhile my significant other miss-placed the wiring diagram by color code and i'm at total loss. there is no schematic on appliance near console, and have no manual. I need wiring by color code to match timer 013-98542 thanks
fairbank56
#2 Posted : Sunday, September 21, 2014 8:41:23 AM(UTC)
fairbank56
Groups: Expert
Timer terminals
A orange
B red, and black wire from drum lamp
C white (2)(one from buzzer) and black wire from timer motor (either one)
TM black wire from timer motor (either one), and one end of resistor
R other end of resistor, and black wire from hi limit thermostat
X tan wires (2)
H brown wire from buzzer
Eric
richardbecker
#3 Posted : Sunday, September 21, 2014 10:47:00 AM(UTC)
richardbecker
I'll give it a try, thank you so much
richardbecker
#4 Posted : Sunday, September 21, 2014 1:23:40 PM(UTC)
richardbecker
Im stiil
having problem, I have no R terminal. A,B,C,S,H,X,TM not sure of the double blks i believe one to C and one to TM. Not finding the resistor. I also have purple wire maybe to S for switch to lite tumble?
fairbank56
#5 Posted : Sunday, September 21, 2014 2:09:26 PM(UTC)
fairbank56
Groups: Expert
Looks like I may be using the wrong wiring diagram. According to the GE parts list, the tech sheet for your model is number 31-15415 however, the parts manual shows your dryer as having a control board but there is no control board on that tech sheet. I've included the tech sheet with wiring diagram but it is apparently not the correct one for your model. Sorry, that's about all I can offer for now unless I find some more information.
Eric
File Attachment(s):
GE 31-15415.pdf (559kb) downloaded 6 time(s).
Timer Wiring (Dryer Repair)
by Rob NY 2/19/2014 10:54:05 AM(UTC)
Dryer Timer Wiring Schematics (Dryer Repair)
by DVO1978 12/13/2013 11:31:20 AM(UTC)
Maytag Timer Wiring (Dryer Repair)
by Big Boy 1/22/2013 9:31:40 AM(UTC)
Defrost Timer Wiring (Refrigerator & Freezer Repair)
by Will D 5/30/2012 3:44:58 PM(UTC)
483212 defrost timer wiring (Refrigerator & Freezer Repair)
by silverbay 11/5/2011 12:41:05 PM(UTC)
Whirlpool timer wiring change? (Washer Repair)
by patbob 10/17/2011 2:51:12 PM(UTC)
Timer Wiring Diagram (Dryer Repair)
by jmalone34 2/7/2011 10:05:40 AM(UTC)
timer wiring problems (Washer Repair)
by juteck 11/28/2010 7:15:59 AM(UTC)
timer wiring (Dryer Repair)
by justn1978 7/20/2010 1:01:48 PM(UTC)
GE DBXR453ET3WW timer wiring help (Dryer Repair)
by Snowboarder81 12/16/2009 12:57:46 AM(UTC)
Whirlpool Dryer Timer Wiring (Dryer Repair)
by leeke02 9/11/2009 4:09:39 AM(UTC)
Timer wiring (Dryer Repair)
by novelistwendy 2/3/2008 3:25:38 PM(UTC)
