I have a no start, no power to J6/ compressor off a new ADC> The reefer showed no previous signs of hard starting, temperature deviation, or any odd noises. I have power to the FF cold control, the lights are on and I have the evaporator fan spinning away. I was an appliance tech once upon a time,but I am out of ideas and i'm hoping somebody has an idea of what i might have mis-wired., or misunderstood.
If you have voltage across the cold control pins, you have a bad cold control.
this would be the pins on the ADC?
i have 118 at the dark blue wire on the def stat, I have 118 @ the violet and white on the top post of the cold control, i have voltage at the freezer control. Only place i don't have voltage is the compressor
Is the condenser/compressor fan on? Whenever it is on the compressor should be on as they are wired in parallel. Why did you replace the ADC? Below is a manual that should be a close match if not the same as your unit. Hopefully it will be helpful. You will have to join the site and be logged in to be able to download it. http://appliancejunk.com...&id=288;t=1410775291 |
THIS FORUM IS DEAD!!!!!!! |
unable to post reply failure value of 20
Sorry but I do not know what the above means.
Perhaps try again and if that does not work start a new post and refer back to this one |
no voltage to condenser fan I installed the ADC as it was billed( on several sites) as "the fix" for non start along with other defrost related problems.Any idea where J6 (on the ADC) gets power? I have the guide, that came with the reefer. Thanks as always for any and all help given Paul
[COLOR="Blue"]Any idea where J6 (on the ADC) gets power?[/COLOR] I am not quite sure I understand the question.
If you are asking about circuitry on the board I cannot help as manufacturers do not publish board schematics. I would think there is a relay on the board that closes.
If you mean power to the board It looks like: Pin 1 black is line Pin 10 light blue is Neutral |
I am not quite sure I understand the question What conditions must be met for J6 to have power?
