2 Pages<12
KENSAR
#11 Posted : Wednesday, September 10, 2014 5:54:39 PM(UTC)
KENSAR
Thank you Eric!
KENSAR
#12 Posted : Friday, September 12, 2014 8:05:31 AM(UTC)
KENSAR
Hello again Eric,
My wife noticed that there is no difference in agitation speed between DELICATE (slow/slow) and NORMAL (slow/fast). Should agitation speeds be different and noticeable? Or only the cycle duration varies? Thank you. Dan
fairbank56
#13 Posted : Friday, September 12, 2014 9:55:50 AM(UTC)
fairbank56
Groups: Expert
Delicate is slow agitation and slow spin. Normal is slow agitation and fast spin. Heavy duty is fast agitation and fast spin. Casual is extra slow agitation and slow spin. Hang dry is fast agitation and slow spin.
Eric
KENSAR
#14 Posted : Friday, September 12, 2014 10:59:20 AM(UTC)
KENSAR
Hello again Eric, Thank you for responding!
Under SPEEDS knob there are 6 settings as follows: HANDWASH PLUS, HANDWASH CASUAL, DELICATE, NORMAL, HEAVY DUTY and HANG DRY. During agitating cycle, if you turn SPEEDS knob there is a change in agitation speeds on all settings except between DELICATE and NORMAL. On both, delicate and normal, agitation speed is the same. This led my wife to think that DELICATE (or NORMAL) mode is not working properly? Dan
fairbank56
#15 Posted : Friday, September 12, 2014 11:40:43 AM(UTC)
fairbank56
Groups: Expert
That is normal. Agitation speed is the same for delicate and normal settings.
Eric
KENSAR
#16 Posted : Friday, September 12, 2014 9:06:54 PM(UTC)
KENSAR
Thank you Eric!
Guest (5)
Kenmore washer won't spin (Washer Repair)
by gorogergo 8/23/2014 12:33:47 PM(UTC)
Kenmore Washer won't spin at all (Washer Repair)
by Mealbee 6/29/2014 1:01:14 PM(UTC)
Kenmore Washer Won't spin (Washer Repair)
by CrossWashappliances 2/2/2014 5:10:05 AM(UTC)
Kenmore washer won't spin or agitate (Washer Repair)
by jwes 1/23/2014 6:22:22 PM(UTC)
Kenmore Washer Won't Spin, Drain Properly (Washer Repair)
by TheDude 12/30/2013 11:53:55 PM(UTC)
90 series kenmore washer won't spin, drain (Washer Repair)
by Beckmd 10/25/2013 3:14:26 PM(UTC)
Kenmore washer won't spin, stop agitating, or drain. HELP! (Washer Repair)
by bwal314 7/15/2013 7:00:50 AM(UTC)
by tbditw 2/3/2013 4:52:34 PM(UTC)
Kenmore Washer won't spin (Washer Repair)
by Electechab 1/29/2013 3:43:56 PM(UTC)
Kenmore washer won't spin correctly at times (Washer Repair)
by phillips1978 6/19/2012 6:46:04 AM(UTC)
Kenmore Washer won't spin, agitate or drain (Washer Repair)
by Micky_577 5/14/2012 9:28:00 AM(UTC)
Kenmore washer won't spinj (Washer Repair)
by duckhunter22 3/10/2012 7:23:13 AM(UTC)
by Little old me 1/28/2012 4:22:51 PM(UTC)
by dmw1209 1/2/2012 7:12:26 PM(UTC)
by pgarbs 9/1/2011 10:19:22 AM(UTC)
2 Pages<12
