aguywithfeet
#1 Posted : Thursday, September 11, 2014 5:10:15 PM(UTC)
aguywithfeet
My dishwasher lower spray arm spins about 12 times a minute and the water jet does not reach the top of the dishwasher. Could this be why it's not cleaning well? I cleaned the filters abd checked all the jets, it had over an inch of water in the bottom. What else could be the problem?
aguywithfeet
#2 Posted : Friday, September 12, 2014 4:18:03 AM(UTC)
aguywithfeet
I think the top section of my telescoping tube that shoots up is missing. I only have two. This would explain my issue right? Seems to make sense.
#3 Posted : Friday, September 12, 2014 5:31:36 AM(UTC)
Parts for GSD3300 - AppliancePartsPros.com
Your model number is missing a couple digits so you will have to choose the correct unit from the Matching Model Numbers section.
You can then take a look at what the arm should look like.
[COLOR="Blue"]This would explain my issue right?[/COLOR]
Yes it would, if indeed there should be 3 sections.
Dryer stops and starts during entire drying cycle, is this normal? (Dryer Repair)
by loric228 1/3/2009 4:36:20 AM(UTC)
I can hear water behind the drum is this normal? (Washer Repair)
by repowoman 10/6/2007 11:58:33 AM(UTC)
