reggieh
#1 Posted : Sunday, August 24, 2014 5:56:45 PM(UTC)
reggieh
I have an issue with water freezing from the back of the Maytag refrigerator/freezer to the ice maker in that water shoot/tube. I would simply pull the tube out and clear the ice from it and reinstall. It would happen only once in a while, but now it has become a weekly nuisance. Sometimes I would have to pull out the ice maker and clear the ice buildup too in the water entry part.
Do I need to replace my whole ice maker, water inlet valve or something else?
#2 Posted : Tuesday, August 26, 2014 2:25:17 AM(UTC)
Parts for Maytag MZD2665HEW Refrigerator - AppliancePartsPros.com
First I would check the freezer temperature perhaps it is just too cold.
It should be between 0 and 5 degrees F.
Next most likely culprit is the water valve.
It could be that it is not closing properly so after it is supposed to close you get a couple extra drops. These freeze in the tube and eventually build up till the tube plugs.
reggieh
#3 Posted : Tuesday, August 26, 2014 9:01:02 AM(UTC)
reggieh
Thank you for the reply. I ordered the part and will see if that resolves the issue.
reggieh
#4 Posted : Thursday, September 11, 2014 11:31:27 AM(UTC)
reggieh
Update. The new part did solve the problem. Thank you for your help!
#5 Posted : Friday, September 12, 2014 1:02:34 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
