woodman46
#1 Posted : 11 years ago
woodman46
No model number. Unfortunately the previous owner scrubbed off the model number from the ID plate. This is a "plain vanilla" Magic Chef Gas Range, about 15 years old. Electronic ignition meaning glow wire for oven, spark igniters for burners. No electronic clock controls--only analog clock with timer.
The oven overheats by 50 degrees. Is there some way to adjust the oven temp? Or is the only solution to buy new oven control with new oven temp sensor?
#2 Posted : 11 years ago
Perhaps the following will help
http://www.applianceaid.com/ele...ics.php#standard-control
take a look at "How to change a standard controlled oven temp:"
woodman46
#3 Posted : 11 years ago
woodman46
Thanks much! Your're a lifesaver. I don't have the adjustable template on the back of the oven knob but I do have the hollow shaft with small screw at the bottom--size of screw on eye glasses. Turned left about 50 degrees. Will see what this brings in terms of temp reduction. I assume this is trial and error?
#4 Posted : 11 years ago
woodman46
#5 Posted : 11 years ago
woodman46
Yes, you were definitely able to help. I also learned that the small screw decreases temp when turned right and increases temp when turned left--same direction as the oven dial increases or decreases temp.
Whirlpool RBS305PDB1 wall oven temp control (Oven Repair (including Ranges and Cooktops))
by WPoven 3 years ago
Westinghouse Oven Temp Control & Model Question (Oven Repair (including Ranges and Cooktops))
by Mark_in_Seattle 15 years ago
by lewmerk 15 years ago
Need new oven temp control (Oven Repair (including Ranges and Cooktops))
by WayneDeLisle 15 years ago
Oven Temp Control Problem (Oven Repair (including Ranges and Cooktops))
by tfarrill 15 years ago
Gas GE Oven temp control knob spinning? (Oven Repair (including Ranges and Cooktops))
by Hokies_fan 16 years ago
Increase oven temp control not working (Oven Repair (including Ranges and Cooktops))
by fioman6740 16 years ago
Whirlpool oven temp control (Oven Repair (including Ranges and Cooktops))
by olivia 16 years ago
Oven temp control (Oven Repair (including Ranges and Cooktops))
by fred1329 18 years ago
