brbckg
#1 Posted : Sunday, September 7, 2014 4:51:22 PM(UTC)
brbckg
My dryer will not start. Lights come on but makes no attempt to start. the timer display shows the bottom half of 2 lines almost looks like "11" only half as tall. The damp light is lite but not as bright as normal. I think another lamp was lite on the other side of the panel too but it isn't bright either. First time happened yesterday and I flipped breaker and checked plug in to make sure seated all the way. I held the reset button for 10 seconds and opened and shut the door. When I came back about 30 mins later it was fine and dryer worked properly. Same thing happened this morning and I held reset and and cycled door switch several times. It eventually decided to work. This afternoon it happened again and I have yet to get it to work. I hope this is something easily fixed and not expensive. Thanks in advance for any suggestions.
#2 Posted : Monday, September 8, 2014 3:05:16 AM(UTC)
Parts for Whirlpool GEW9250PW0 Dryer - AppliancePartsPros.com
See the attachment for the tech sheet
Unfortunately it sounds like it is a control board problem (item 19 in section 01)
You could try running the diagnostics.
File Attachment(s):
GEW9250.pdf (306kb) downloaded 13 time(s).
Whirlpool Duet dryer will not start. Sensing light on then a click. (Dryer Repair)
by dmariola 4/12/2012 6:47:43 AM(UTC)
