skidaddy
#1 Posted : Sunday, September 7, 2014 4:41:05 PM(UTC)
skidaddy
I have a Whirlpool Quite Partner 2 dishwasher. The Cancel and Normal lights are flashing rapidly and non stop. I was told at another site it was the Control Board. So spent the money and replaced it. Now Just the cancel light is flashing rapidly and non stop. The unit will not respond to anything. Tried the diagnosis test by disconnecting the 14 pin connector at the control board and ran the unit. The pump came on and ran for 2 minutes. From what I am understanding now the Control Panel is
what is bad. I checked it for burns on y
the ribbon and pull of the sticker on the front to check the ribbon and buttons. All looks good. I have read on the forum that other have had buttons bent or stuck! Before I spend another $150 I would like to verify I cant fix something bent or stuck first and knowledge its indeed the panel is junk!!!!!!
ANY HELP??????
SKIDADDY
#2 Posted : Monday, September 8, 2014 9:22:36 AM(UTC)
Parts for Whirlpool DU1101XTPB8 Dishwasher - AppliancePartsPros.com
Check the key output at the ribbon cable with a meter to see if it is always closed.
See the tech sheet.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
DU1101.pdf (244kb) downloaded 3 time(s).
blinking cancel light.... door latch? (Dishwasher Repair)
by DPForumDog 11/16/2014 8:20:10 AM(UTC)
