DPForumDog
#1 Posted : Sunday, November 16, 2014 8:20:10 AM(UTC)
DPForumDog
Our dishwasher has had the blinking cancel light for several years. At first I would do the reset thing by toggling back and forth between hi temp and energy saver buttons and this would fix it, for a while.
Sadly the toggle trick no longer works.
We tested the ohms on the heater and hi temp thermostat and both are fine. So now we are looking at the latch.
Our latch is broken exactly like the one in the video below,
Whirlpool 8269117 Dishwasher Door Latch Handle - AppliancePartsPros.com
but our dishwasher opens and closes fine and runs for about 40 minutes before we get the blinking lights.
The video doesn't say anything about this broken part causing the water not to heat, which would in turn cause the blinking cancel issue.
Could the little broken part in the video cause the issue?
Thanks,
Granny DP
#2 Posted : Monday, November 17, 2014 2:24:34 AM(UTC)
[COLOR="Blue"]Could the little broken part in the video cause the issue?[/COLOR]
Yes
See the attachment for your tech sheet.
As you can see in the tech sheet your door latch has two switches and one of them does kill power to the heater so it that switch is bad or not being closed it could cause your problem.
File Attachment(s):
KUDI01IL.pdf (163kb) downloaded 5 time(s).
DPForumDog
#3 Posted : Monday, November 17, 2014 5:20:09 AM(UTC)
DPForumDog
My husband temporarily bypassed the latch (yes it would still run even with the door open). But we still got the blinking light.
He thinks that bypassing the latch and still having the problem points to the Control board. What do you think?
Granny DP
#4 Posted : Monday, November 17, 2014 10:54:18 AM(UTC)
I would agree with him as long as he has gone through the tech sheet and cannot find another cause.
