4 Pages<1234>
rebelyelljr
#21 Posted : Monday, May 11, 2009 1:42:09 PM(UTC)
rebelyelljr
ok. I'm about to go do that now.
What if it does have ice in it...what are my options. What do i replace or do overall?
i am gonna go do it now...
rebelyelljr
#22 Posted : Monday, May 11, 2009 1:52:14 PM(UTC)
rebelyelljr
yep its frozen.
ok i cleared out as much as i could see but still no water flow. could the freeze be deeper down? Should i sit with a hair dryer for a long time? or just switch the cords and hit the automatic water dispenser untill it pushes through?
rebelyelljr
#23 Posted : Monday, May 11, 2009 2:29:03 PM(UTC)
rebelyelljr
Ok. now i am really clueless....and frustrated. I cleaned out all of the ice inside the fill tube. disconnected the line going up the back of the freezer onthe outside and took another little peice of tubing and blew water from the back of the freezer on the outside into the freezer on the inside, simulating the outside line and the fill tube. I switched the wires so that the water on the door pushes water up the tube on the outside of the freezer and with the tube disconnected on the outside it works just dandy. pushes water up the tube and out the top. But every time i hook up the tube in the back of the freezer it woln't push water out into the freezer? I am totall clueless? i mean i push the water lever on the door and pull the tube out and it starts shooting water everywhere, but as soon as i put it back in the water stops? how is that possible? makes no sense?
woodchuckie
#24 Posted : Monday, May 11, 2009 3:58:11 PM(UTC)
woodchuckie
disconnected the line going up the back of the freezer onthe outside and took another little peice of tubing and blew water from the back of the freezer on the outside into the freezer on the inside, simulating the outside line and the fill tube. I switched the wires so that the water on the door pushes water up the tube on the outside of the freezer and with the tube disconnected on the outside it works just dandy. [COLOR="DarkOrange"]Is it disconnected at the top where it goes in the freezer. [/COLOR] pushes water up the tube and out the top. But every time i hook up the tube in the back of the freezer it woln't push water out into the freezer? [COLOR="DarkOrange"]Can you blow air thru it from the bottom with it connected at the top[/COLOR] I am totall clueless? i mean i push the water lever on the door and pull the tube out and it starts shooting water everywhere, but as soon as i put it back in the water stops? how is that possible? makes no sense?
[COLOR="DarkOrange"]I wondering if there is some kind of blockage in the elbow connector at the top. [/COLOR]
rebelyelljr
#25 Posted : Monday, May 11, 2009 3:59:26 PM(UTC)
rebelyelljr
Everything works up until that elbow. I tdidn't disconnect it at the bottom and blow air through to the top. I'll try that i guess but...
rebelyelljr
#26 Posted : Monday, May 11, 2009 4:02:13 PM(UTC)
rebelyelljr
i am pretty sure there is no blockage in the elbow connector because like i say...i took a half a mouth of water...and a straw...stuck the straw up the hole where the line was in the back of the freezer at the top....and was able to blow alittle water in the the freezer. And with it connected to everything but the top elbow it blows water?
rebelyelljr
#27 Posted : Tuesday, May 12, 2009 8:07:27 AM(UTC)
rebelyelljr
thoughts? i'm at my wits end...doesn't make sense....?
rebelyelljr
#28 Posted : Tuesday, May 12, 2009 5:08:29 PM(UTC)
rebelyelljr
So do you think i need a new valve? i don't wanna waste the money if i don't have to...but i'm frankly sick of making ice cube trays....:(
woodchuckie
#29 Posted : Tuesday, May 12, 2009 6:27:51 PM(UTC)
woodchuckie
With the wires swapped on the valve, the water dispenser will send water to the ice maker? If yes then replace the valve. If not, no.
rebelyelljr
#30 Posted : Wednesday, May 13, 2009 5:20:49 AM(UTC)
rebelyelljr
the answer is no. I can't get water to send to the ice maker regardless.
as soon as i hook it up to the back of the freezer is stops pushing water to up the tube. as soon as i disconnect it, at the top, it pushes water up the top.?
thoughts?
Guest (14)
4 Pages<1234>
