dcromer4
#1 Posted : Monday, August 25, 2014 12:36:59 PM(UTC)
dcromer4
Hello , the dishwasher doesn't seem to latch closed securely. It still works but it leaks.
#2 Posted : Tuesday, August 26, 2014 2:04:24 AM(UTC)
Parts for Maytag MDB8951AWQ - AppliancePartsPros.com
Check that the unit is level front to back.
Check that the door springs are OK.
Check the door seal.
Check the door latch.
From your post it sounds like the latch is the most likely cause re: seal is not sealing at the top of the door.
dcromer4
#3 Posted : Tuesday, August 26, 2014 3:32:00 PM(UTC)
dcromer4
I wonder if this model has a history of latch problems. Is it hard to replace a latch. Harry homeowner
#4 Posted : Wednesday, August 27, 2014 4:20:53 AM(UTC)
Should not be that difficult.
If you click on a part's picture or description a new page will open with additional info on that part. Often there is a A&Q section that can be helpful.
dcromer4
#5 Posted : Wednesday, August 27, 2014 3:43:22 PM(UTC)
dcromer4
Thank you for your help
