AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
does't seem to close properly, but works just leaks
Hello , the dishwasher doesn't seem to latch closed securely. It still works but it leaks.
Here are your parts Parts for Maytag MDB8951AWQ - AppliancePartsPros.comCheck that the unit is level front to back. Check that the door springs are OK. Check the door seal. Check the door latch. From your post it sounds like the latch is the most likely cause re: seal is not sealing at the top of the door. |
THIS FORUM IS DEAD!!!!!!! |
I wonder if this model has a history of latch problems. Is it hard to replace a latch. Harry homeowner
Should not be that difficult.
If you click on a part's picture or description a new page will open with additional info on that part. Often there is a A&Q section that can be helpful. |
Dishwasher Repair
