merc0230
#1 Posted : Wednesday, August 27, 2014 2:54:24 AM(UTC)
merc0230
As the title suggests, I have already replaced the control board, heater and thermostat.
I will say that the control board was a little different as the replacement (p/n WR55X10942) had places for 2 additional pin connections, but via my google research it seemed like it was the right replacement (I assume rev changes).
I also bought the main board new off of ********, so I guess there is a chance that it is just not working.
My freezer coils are still freezing up which in-turn keeps my frig from cooling.
Any other ideas before I trash this frig?
#2 Posted : Thursday, August 28, 2014 3:28:24 AM(UTC)
Locate the 3 pin, gray power connector on the motherboard. Unplug it and stick a wire jumper between the mating pins as labeld on the motherboard line and def.
If fridg now defrosts, I would try new evaporator and freezer thermistors.
