D W M
#1 Posted : Tuesday, August 19, 2014 7:43:07 AM(UTC)
D W M
inside back wall of the dryer. As the clothes dry in automatic that sensor adjust the time accordingly. Check to make sure that those strips are clean and that there is no "debri" on them. If they are clean then you are probably into a thermostat.
Yes but the picture you show is not the sensor bar
I,m looking for the wire connections points
There are 4 on sensor 2 on each side, 4 in total
I need to know where the 2 connections (blue and green)
Model MDE9606AZW Maytag drier
#2 Posted : Saturday, August 23, 2014 1:35:58 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Maytag MDE9606AZW Dryer - AppliancePartsPros.com
I cannot see the 4 connectors at the sensor looking at the part's picture but it should not matter.
One wire goes to one of the metal strips and the other wire goes to the other strip.
It does not matter which wire goes to which strip.
fairbank56
#3 Posted : Saturday, August 23, 2014 4:09:13 AM(UTC)
fairbank56
Groups: Expert
#4 Posted : Saturday, August 23, 2014 4:19:00 AM(UTC)
Sorry fairbank56
I did not notice that he had duplicate posts
Where connect the 2 wires to the 4 connections on sensor bar (Dryer Repair)
by D W M 8/19/2014 7:37:31 AM(UTC)
