hhudsonn
#1 Posted : Thursday, August 21, 2014 12:20:56 PM(UTC)
hhudsonn
Unit will not get below 60 degrees, checked coil in fridge and fan, fan works, coil is not frozen. Checked coil and fan in freezer, coil is not frozen and fan works.
Compressor is warm to touch, and fan under fridge is running.
Any idea what I should check next?
It is a Whirlpool French door model #wrf989sdae00
#2 Posted : Thursday, August 21, 2014 12:57:40 PM(UTC)
Measure the freezer temperature and post.
hhudsonn
#3 Posted : Thursday, August 21, 2014 5:52:20 PM(UTC)
hhudsonn
Currently, the fridge is 55 and the freezer is 60. Has been running with doors shut for 10 hours or more
#4 Posted : Friday, August 22, 2014 12:30:52 AM(UTC)
If the compressor is not vibrating, replace the start device.
hhudsonn
#5 Posted : Friday, August 22, 2014 4:43:32 AM(UTC)
hhudsonn
Compressor is vibrating and warm to touch.
#6 Posted : Friday, August 22, 2014 6:55:47 AM(UTC)
\You have an evaporator leak/ bad compressor, too costly to fix/
hhudsonn
#7 Posted : Friday, August 22, 2014 7:18:57 AM(UTC)
hhudsonn
Ouchie, too costly? It is a $2500 unit, and less than 2 years old
I found this link, model WRF989SDAF00 whirlpool frig. - The Kitchen Appliance Repair Forum - The Samurai Appliance Repair Forums
My serial number falls in the range, but my model number is E instead of F
Guest (4)
