dpickerel
#1 Posted : Wednesday, August 20, 2014 6:28:53 PM(UTC)
dpickerel
I have a refrigerator that has slowly been wearing down. First, the defrost quit working, then it start coming on every few days for a few days, then off for a few days.
I've replaced both the defrost thermostat harness and the defrost timer. Before i replaced the defrost timer the compressor only ran when the defrost heater was on, but it got stuck and kept getting hotter until i unplugged it. Now nothing is running since i installed the new defrost timer. The light comes on, but that's it.
I don't really want to get a new refrigerator right now because i won't need it in a few months. And the compressor seems to run fine when it does run. But other than the thermostat i can't thing of anything else to look at.
#2 Posted : Thursday, August 21, 2014 1:21:14 AM(UTC)
Seems like you have a wiring problem, you will need a meter to check.
dpickerel
#3 Posted : Thursday, August 21, 2014 10:42:04 AM(UTC)
dpickerel
No kidding? Brilliant!
#4 Posted : Thursday, August 21, 2014 12:28:27 PM(UTC)
You have not provided any info that will help us with your problem. You may have plugged a connector in wrong, which is usually impossible to do, or you have a serious wiring problem that we cannot solve for you without looking at the item.
dpickerel
#5 Posted : Thursday, August 21, 2014 12:39:50 PM(UTC)
dpickerel
yep, modular and pretty impossible to plug them in wrong without breaking things.
Absolutely a waste of time here.
Guest (4)
