Ge oven bake element will not turn off, I have unplugged the oven and let it be overnight the pugged it back in and still there is power to the lower element, actually burned thru the lower element.
Joined: 2/29/2008(UTC) Views messages in topic : 19,638
Here are your parts Parts for GE JBP79WW1 Range - AppliancePartsPros.comI am assuming that the element was a fairly even red along it's length when it was heating. If it was red on only part of it then it could be a grounded element. The most likely cause is a blown control board re: the relay that controls the element is not opening. |
THIS FORUM IS DEAD!!!!!!! |
