have a Kenmore side by side fridge just got a few days ago.the display has 2 lines lit up on the freezer temp control side.When unplugged and plugged back in the fridge display works fine for a while, then the display will go back to 2 lines with a lock out mode. so far the fridge is cold enough, same with the freezer... but I have not the heard the compressor turn off yet,it been 4 days
:confused: ;) i have a kanmore side x side model 79558813900 the problem is the evapored fan doesnot work and the other fan eitheir,please help me
For thaberko, measure the freezer temperature and post.
don't have nothing at the movement..i put a glass of water in the freezer almost 24 hours..the water is not even frozen..
Check to see if the compressor in the back is warm and vibrating.
its warm and not vibrating
update the compressor has been turning off and back on like it post to and freezer got cold to freeze the water but now the freezer is getting warm
Something is intermittent like a bad control.
temps are freezer 15f and fridge 57f
