thaberko
#1 Posted : Friday, August 15, 2014 8:16:01 AM(UTC)
thaberko
have a Kenmore side by side fridge just got a few days ago.the display has 2 lines lit up on the freezer temp control side.When unplugged and plugged back in the fridge display works fine for a while, then the display will go back to 2 lines with a lock out mode. so far the fridge is cold enough, same with the freezer... but I have not the heard the compressor turn off yet,it been 4 days
angelo19741
#2 Posted : Saturday, August 16, 2014 8:34:14 AM(UTC)
angelo19741
:confused: ;) i have a kanmore side x side model 79558813900 the problem is the evapored fan doesnot work and the other fan eitheir,please help me
#3 Posted : Saturday, August 16, 2014 1:58:24 PM(UTC)
For thaberko, measure the freezer temperature and post.
thaberko
#4 Posted : Saturday, August 16, 2014 10:37:37 PM(UTC)
thaberko
don't have nothing at the movement..i put a glass of water in the freezer almost 24 hours..the water is not even frozen..
#5 Posted : Sunday, August 17, 2014 12:36:17 AM(UTC)
Check to see if the compressor in the back is warm and vibrating.
thaberko
#6 Posted : Sunday, August 17, 2014 9:12:50 AM(UTC)
thaberko
its warm and not vibrating
thaberko
#7 Posted : Sunday, August 17, 2014 6:40:56 PM(UTC)
thaberko
update the compressor has been turning off and back on like it post to and freezer got cold to freeze the water but now the freezer is getting warm
#8 Posted : Monday, August 18, 2014 1:15:38 AM(UTC)
Something is intermittent like a bad control.
thaberko
#9 Posted : Wednesday, August 20, 2014 5:08:25 AM(UTC)
thaberko
temps are freezer 15f and fridge 57f
