Originally Posted by: neveraging  Just moved into a home with one of these devilish dishwashers. Relieved that it is not just me (it's been 5 years since I had a dishwasher and thought I must be loading wrong or something), but yeah the dishes (especially pots) come out hideous.
My question is: How do you take apart the arms to clean the nozzles? I don't want to break it just yet.
THANKS! For our model (PDW8480J10SS), the upper spray arm (beneath the top rack) can be removed using a nut driver. For the lower spray arm, lift up gently and rotate it counter-clockwise; it will "unscrew" from the 'fine filter hub nut' (454). To clean these, I take them to our stationary tub and use a hose to blast the water in/out of every hole. I find it helpful to use an old dental tool (hardware store bargain bin) to help coax out the food bits. The ends are usually the worst, and may require some persistence to rinse all the junk out of the arm.
