jedwards
#1 Posted : Friday, December 14, 2007 10:12:11 AM(UTC)
jedwards
I ordered an adaptive defrost control from Parts Pros. using the sites diagrams and parts list. It is item number 13 on the controls diagram, part #MAC 61005988. This is the part I received, however, it does not exactly match the part it is replacing. The new part is a circuit board with fewer transistors and chips on it even tho the pin connector is the same. Sears has a similar diagram on their web site. It lists several different "series" for this refrigerator. I am told that mine is a series 10. Part # MAC 61005988 matches up with a series 19. The part for a series 10 is part # 61003990. I called customer service about this and they said that these defrost controls are interchangeable, but they also said to contact this forum. I don't want to plug this new part in and find out the hard way that it won't work. What is your verdict?
#2 Posted : Friday, December 14, 2007 3:23:17 PM(UTC)
All different kind of the previously used adaptive defrost controls have been changed by the Maytag to the one with the part number Part number: 61005988
Since that this is the only one adaptive defrost control available for all Maytag MZD27766GEQ models refrigerators with different serial numbers.
jedwards
#3 Posted : Saturday, December 15, 2007 6:24:03 AM(UTC)
jedwards
:) Thank you very much for the quick reply!! Jay
mwongism
#4 Posted : Saturday, September 27, 2008 7:40:28 AM(UTC)
mwongism
I have the same problem and ordered a new Adapter Defrost (MAC 61005988). I have a Maytag Wide-by-Side (model MZD2766GEB) and when I put the new part in, the fan comes on for a second and then will not come back on. I put the old part back in and the fan comes on and the fridge works (until the ice builds back up). Did I just receive a bad part?
#5 Posted : Tuesday, September 30, 2008 4:55:05 PM(UTC)
Originally Posted by: mwongism Go to Quoted Post
...Did I just receive a bad part?...
Looks like.
okbobcats
#6 Posted : Wednesday, October 1, 2008 4:02:11 AM(UTC)
okbobcats
your defrost timer could of been good you may have a bad bimetal of heater
mwongism
#7 Posted : Friday, October 3, 2008 4:47:59 PM(UTC)
mwongism
Thanks for the responses;
Just got a new Defrost Timer from the company and it does not work either. I got it from a different place.
okbobcats...what is a "bimetal of heater" and how can i tell if it's bad
okbobcats
#8 Posted : Saturday, October 4, 2008 2:47:19 AM(UTC)
okbobcats
Its on the evap coil in the freezer. it should be closed at 15 Degrees and open at 55 degrees.cits a little round thing with twoo wires going to it.
Adaptive Defrost Control Frigidaire (Refrigerator & Freezer Repair)
by KYyankee 5/6/2017 7:24:01 AM(UTC)
Adaptive Defrost Control (Refrigerator & Freezer Repair)
by jiminoregon 5/18/2014 2:54:44 PM(UTC)
Adaptive Defrost Control #61005988R (Refrigerator & Freezer Repair)
by jiminoregon 3/1/2014 8:53:49 AM(UTC)
Adaptive defrost controller (Refrigerator & Freezer Repair)
by jcf33 3/20/2012 10:51:11 AM(UTC)
Adaptive Defrost Control Board (Refrigerator & Freezer Repair)
by pkula 3/12/2012 6:29:10 AM(UTC)
Can an adaptive defrost control board be tesed? (Refrigerator & Freezer Repair)
by Mott4 4/13/2011 9:05:31 AM(UTC)
adaptive defrost control or defrost element (Refrigerator & Freezer Repair)
by whiplash 7/5/2010 6:46:42 PM(UTC)
Manually Cycle Adaptive Defrost Control (Refrigerator & Freezer Repair)
by DIYRob 7/13/2009 7:54:24 AM(UTC)
Freezer Thermostat or Adaptive Defrost Control?? (Refrigerator & Freezer Repair)
by bet_now 5/30/2009 11:44:35 AM(UTC)
Does my Maytag have a defrost timer or adaptive defrost control? Where is it? (Refrigerator & Freezer Repair)
by Momto8 5/6/2009 11:56:41 AM(UTC)
