Boyd Cable
#1 Posted : Tuesday, July 29, 2014 11:14:08 AM(UTC)
Boyd Cable
The display is so dim I can barely read it.
it is ser#15266042SO.
Suggestions as to a fix.
#2 Posted : Wednesday, July 30, 2014 1:08:25 AM(UTC)
Parts for Jenn-Air SCE30600W Range - AppliancePartsPros.com
The control board has a problem.
Unfortunately the control board is missing from the listing.
You will have to call them to see if it is still available.
Note that there are companies out there that will fix obsolete control boards, just Google "appliance timer repair"
If this is a fluorescent type display you may be able to fix it yourself.
Often a dim display is due to a problem with an electrolytic capacitor on the control board, see the below info.
http://forum.appliancepartspros...ml?highlight=dim+display
Kitch Aid Oven Dim Display (Oven Repair (including Ranges and Cooktops))
by sle1 3/25/2013 7:37:09 AM(UTC)
loud fan and dim display on Kitchen aid Oven (Oven Repair (including Ranges and Cooktops))
by hartsellemom 3/18/2013 9:57:31 AM(UTC)
Thermador dim display (Oven Repair (including Ranges and Cooktops))
by sidneywooten 2/11/2013 2:52:04 PM(UTC)
Thermador Dim Display and knobs (Oven Repair (including Ranges and Cooktops))
by Jacques102 9/19/2012 9:28:00 AM(UTC)
Jenn-Air Model door won't close and dim display (Oven Repair (including Ranges and Cooktops))
by lovenmygirls 4/4/2012 5:28:39 PM(UTC)
Dim Display on Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by stevest 12/3/2010 4:08:55 AM(UTC)
by eonbama 5/5/2010 9:54:04 AM(UTC)
Electric Double Oven.. had dim display (Oven Repair (including Ranges and Cooktops))
by kbrophy 1/7/2010 8:51:27 AM(UTC)
Jen-Air stove dim display (Oven Repair (including Ranges and Cooktops))
by richappy 9/15/2009 11:22:17 AM(UTC)
F1 error and very dim display (Oven Repair (including Ranges and Cooktops))
by mikefoos 8/21/2009 10:39:23 AM(UTC)
by Billgeo 7/16/2009 7:19:00 PM(UTC)
Dim Display / Fan Running (Oven Repair (including Ranges and Cooktops))
by kikakeith 12/10/2008 9:47:56 AM(UTC)
Dim display thermador double oven (Oven Repair (including Ranges and Cooktops))
by Alvin 12/31/2007 2:16:00 PM(UTC)
