kbrophy
#1 Posted : Thursday, January 7, 2010 11:51:27 AM(UTC)
kbrophy
I have 3 year old Whirlpool double electric oven RBD305PRS00.
It encountered dim display after use of both ovens over extended time;
Xmas cookie baking in Dec 2009.
After reading several internet posts on problem of dim display, I did power off and power on at fuse box; at that time still dim display.
After 2 days ...the display returned to original (not dim) state.
Is this story of damaged capacitors on control panel? or other?
Will the display remain okay or should I prepare for a new control panel
(part 8303883 for approx. $200)
Also, how to remove?
marksk
#2 Posted : Tuesday, March 9, 2010 11:49:17 AM(UTC)
marksk
this just happened to me, same model, three years old. noticed one day last week the time was dimming, within two days it was so faint you couldn't see it unless all lights were off. panel still beeps when buttons are pressed and the oven still heats up. i turned off the power at the breaker for a few minutes, but nothing happened. should i try the breaker again? what course of action should i take next?
thanks!
eadam
#3 Posted : Monday, April 12, 2010 7:15:25 PM(UTC)
eadam
Our oven has a very dim display. I can only see the time faintly. Everything else works well. I'm not sure if its a fuse or something else with the panel. Thought I would inquire first to see if I could repair myself before I call a repairman.
Thanks for any insight.
eadam
#4 Posted : Monday, April 12, 2010 7:19:39 PM(UTC)
eadam
Our oven has a very dim display. I can only see the time faintly. Everything else works well. I'm not sure if its a fuse or something else with the panel. Thought I would inquire first to see if I could repair myself before I call a repairman. Oven model #rbd305pdb.
