2767D
#1 Posted : Sunday, May 10, 2009 12:12:04 PM(UTC)
2767D
when the motor try's to start it trips the relay and shuts down the washer,I removed the belts and it starts fine, I can push motor ahead so the belt slips a little and then it will go, I checked the running amps are about 6 when washer is running and about 3 with no belts, when it try's to start they are about 14, is it the motor or the starter.
sidfink43
#2 Posted : Monday, May 11, 2009 2:58:54 PM(UTC)
sidfink43
This sounds very much like the motor, but we cannot be certain, and you will have to purchase and install a new motor to see if that is the problem.
Sorry we cannot be more certain, good luck and let us know what happens.
dryer motor troubleshooting (Dryer Repair)
by patdoc 7/21/2008 9:31:11 AM(UTC)
Motor trouble (Washer Repair)
by GeorgeG 3/27/2008 9:22:03 PM(UTC)
