We experienced a power outage yesterday, when power was restored the oven display is now set to Celsius. How do I get it back to Fahrenheit. . Thanks
Will simply unplugging this unit reset it to factory settings?
Unplugging the unit for a couple minutes should reset it to the defaults. Problem is I do not know which temperature is the default. Are you sure that the model number is correct as nothing comes up when I use it? Could it be a RF370LXPQ0? If yes then below is the operators manual. Take a look at Page 12. http://www.whirlpool.com/webapp...gId=-1&storeId=10211 |
THIS FORUM IS DEAD!!!!!!! |
