Dungles1952
#1 Posted : Monday, July 21, 2014 7:09:30 AM(UTC)
Dungles1952
After removing the motor rotor, both the rotor and the stator were extremely grimy. What is the best (safest) way to clean the grime off without damaging the stator? I have purchased a new motor rotor as the one on the unit had a broken piece.
#2 Posted : Tuesday, July 22, 2014 3:03:43 AM(UTC)
Isopropyl alcohol should do the job and not damage anything.
Unless it is causing a problem sometimes it is just better to leave well enough alone.
Dungles1952
#3 Posted : Tuesday, July 22, 2014 8:32:10 AM(UTC)
Dungles1952
Thank you.
