I have been having issues with my ice maker for a couple of weeks. Last night, I adjusted the flow screw hoping to fix the issue. I stupidly did not bother unplugging the fridge before removing or re-installing the ice maker. As I was re-installing it, the light in the freezer suddenly went out. Now the light doesn't work, the ice maker does nothing, even the motor to turn auger to scoop out ice doesn't work. From what I can tell, the rest of the fridge still has power though.
I think I may have pulled something loose, or maybe thrown a circuit breaker or fuse in the appliance while attaching the wiring harness back to the ice maker.
Any suggestions?
Nevermind. I figured it out. The wiring harness connects to a port in the back of the freezer, and I had pulled it out.
