ak97
#1 Posted : Tuesday, July 1, 2014 2:01:55 PM(UTC)
ak97
just wondering if the fan running continually is normal?
#2 Posted : Wednesday, July 2, 2014 1:46:49 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Maytag MTB2455DRW Refrigerator - AppliancePartsPros.com
No it is not normal for the fan to run all the time.
Note that the evaporator/freezer fan, the condenser/compressor fan and the compressor are wired in parallel so when one is on all should be on.
I would start by checking the freezer (0 to 5 degrees F) and the fresh food (around 40 degrees F) temperatures.
If the temperatures are colder it may be a control thermostat problem.
If the temperatures are warmer remove the rear cover in the freezer to check the evaporator coils.
If heavily iced/frosted over it is probably a defrost problem.
If there is frost uneven (usually just frost where the freon enters the coils) then it is a sealed system problem.
fan runs all the time!!! (Refrigerator & Freezer Repair)
by ak97 7/1/2014 1:30:19 PM(UTC)
