juddgrossman
#1 Posted : Monday, June 23, 2014 12:47:54 PM(UTC)
juddgrossman
No cold water entering the drums. There is water to the inlet valve. When I move the hot water wires to the cold water solenoid the solenoid works, so inlet valve seems o.k.. What is my next trouble shooting step?
fairbank56
#2 Posted : Monday, June 23, 2014 3:02:46 PM(UTC)
fairbank56
Groups: Expert
May be faulty temp switch. Unplug washer, unplug wires from terminals 1 and 3 on back of temp switch. With switch set to cold/cold, you should have continuity between terminal 1 and 3. If not or you read high resistance, replace switch. Part number is WH12X999. When I look up this part number on APP, it gives replacement part WH12X10498 and the photo's show a switch with only 4 terminals. Your switch should have 5 terminals.
Eric
juddgrossman
#3 Posted : Tuesday, June 24, 2014 7:10:08 PM(UTC)
juddgrossman
No continuity between 1 and 3. I ordered a new WH12X999. Thanks!
juddgrossman
#4 Posted : Monday, June 30, 2014 9:08:10 AM(UTC)
juddgrossman
The new WH12X999 just came and it only has 4 terminals. Can I make it work?
fairbank56
#5 Posted : Monday, June 30, 2014 9:48:05 AM(UTC)
fairbank56
Groups: Expert
Should work ok. After looking at the wiring diagram and timer chart again, I see no function whatsoever for the blue wire at terminal 5. Weird. Is your original switch a 3 position switch or 4?
Eric
juddgrossman
#6 Posted : Monday, June 30, 2014 12:55:41 PM(UTC)
juddgrossman
I installed the 4 terminal switch. Seems to work o.k.
juddgrossman
#7 Posted : Monday, June 30, 2014 12:58:13 PM(UTC)
juddgrossman
Original is a three position switch: cold/cold, warm/cold, hot/cold. The original switch had 5 terminals. New one has 4 terminals, so now blue wire goes nowhere. Seems to work fine with the 4 terminal switch.
fairbank56
#8 Posted : Monday, June 30, 2014 1:18:10 PM(UTC)
fairbank56
Groups: Expert
Some of these older models had a 4 position temp switch that included a warm/warm setting (warm rinse). Terminal 5 and the blue wire were to provide for the warm rinse. Still doesn't make sense though that there is a 5 terminal switch with only 3 positions and no function of terminal 5 and blue wire. Anyway, your back in business.
Eric
juddgrossman
#9 Posted : Monday, June 30, 2014 3:56:20 PM(UTC)
juddgrossman
Yup. Thanks for your help!
