vecaz
#1 Posted : Friday, May 8, 2009 6:55:56 PM(UTC)
vecaz
Machine Wont Spin , Drain , Or Agitate. Motor Is On And Noise Is Coming From Near The Motor But Nothing Works. Have I Blown The Transmission Or The Coupler Or What? Thanks For Your Help.
sidfink43
#2 Posted : Saturday, May 9, 2009 5:34:43 PM(UTC)
sidfink43
Check your motor coupling, as this video will show. Note, you do not need to remove the pump, just tie it off to the left.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Let us know what you find. If it is not the motor coupling run the machine with the cabinet off and see if you can locate what noise you have.
Good luck
vecaz
#3 Posted : Saturday, May 9, 2009 8:16:18 PM(UTC)
vecaz
Good luck
reply-- thanks sidfink43 thats exactly what is was, vecaz
sidfink43
#4 Posted : Sunday, May 10, 2009 5:39:09 AM(UTC)
sidfink43
Great, glad you got it fixed and thanks for updating us.
Guest (5)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Whirpool Washer hums but does not spin (Washer Repair)
by markob 6/27/2014 7:20:54 AM(UTC)
Whirpool washer agitates but wont drain or spin (Washer Repair)
by kmsimpso 5/10/2014 9:17:09 AM(UTC)
Whirpool Washer - need help! (Washer Repair)
by jbrixey1@hotmail.com 3/31/2014 5:57:44 AM(UTC)
Whirpool washer making whirring noise (Washer Repair)
by junksasa 6/4/2013 7:18:47 AM(UTC)
whirpool washer stopped at rinse cycle and wont drian or spin (Washer Repair)
by janie527 6/1/2013 4:04:39 PM(UTC)
Whirpool washer won't drain, makes grinding noise (Washer Repair)
by coldbeerchief 1/7/2013 8:40:06 PM(UTC)
Whirpool Washer not aggitating/Spinning (Washer Repair)
by Cielo 10/24/2012 8:48:29 AM(UTC)
Whirpool washer not spinning, desperately need your help please (Washer Repair)
by dro53 9/16/2012 10:41:49 AM(UTC)
Whirpool Washer Will No Go To Rinse Cycle (Washer Repair)
by roperstopper 9/7/2012 7:07:09 AM(UTC)
Whirpool Washer - Clothes Wet After Spin (Washer Repair)
by lester100 7/17/2012 10:59:12 AM(UTC)
whirpool washer fills but wont shut off (Washer Repair)
by pete1949 6/29/2012 11:57:43 AM(UTC)
whirpool washer will agitate but will not spin (Washer Repair)
by Menard70506 6/1/2012 11:57:33 AM(UTC)
Whirpool washer Ultimate care 11 won't rinse or spin (Washer Repair)
by rckrhea2010 2/21/2012 4:41:04 PM(UTC)
Whirpool washer not working (Washer Repair)
by Chicago3110 2/1/2012 12:37:17 PM(UTC)
