Had to put a new relay on the compressor. The unit was off for a couple of days while I got the part. It cools just fine now but the ice maker is not working. it worked fine before the relay on the compressor went bad.
Where do I start to diagnose the problem?
Make sure that the freezer temp is below 8 degrees!!!! The icemaker will not work above this temp!!!:)
Temp is below 8 degrees, it made one batch of ice cubes last night but hasn't since. What next?
Raise the cut off arm up and let it drop down hard. If there is not water in the ice mold, fill it manually and see if it starts when the ice dumps.
