jeffrey_benjamin
#1 Posted : 15 years ago
jeffrey_benjamin
hi i'm still having a problem with this GE refrigerator I replaced the motherboard but display light still flashing, cannot set temp etc no ice or water, but ref. works fine:confused: help needed with this problem
#2 Posted : 15 years ago
Perform the self diagnosis test as described in the attached instructions and post the results.
File Attachment(s):
jeffrey_benjamin
#3 Posted : 15 years ago
jeffrey_benjamin
thanks for the info Gene the condition I have is that the display on the freezer flashes then 0 00 comes on flashing then dissappears this goes on over & over pressing or holding colder or warmer button has no effect :confused:
#4 Posted : 15 years ago
Sounds like the temperature control board is the culprit. The model number you posted does not come up. If you need the correct part number, verify the model number and repost it.
jeffrey_benjamin
#5 Posted : 15 years ago
jeffrey_benjamin
ok thanks again will go on the job & recheck model # & post it
jeffrey_benjamin
#6 Posted : 15 years ago
jeffrey_benjamin
hi Gene replaced the temperature control board & all is well. thanks for your help Jeffrey:)
#7 Posted : 15 years ago
You are welcome, Jeffrey. I'm glad you were able to fix it.
mllambi
#8 Posted : 11 years ago
mllambi
Hi! I have the same issue with my GE side by Side refrigerator (GSS23QSTASS). It started to frost on the back of the fridge and then the temperature in both the refrigerator and the fridge started to go up. I figured it is an issue with the Mother Board. I investigated learned that the mother board for this model was discontinued and replaced by a new one with more components but that according to GE it should work just as the older one (Part WR55X10552 was replaced by WR55X10942). When I replace the motherboard I got the error problem in the display.
I see from your post that maybe I also need to replace the Temperature Control Board? Could it be that the new Mother Board cant communicate properly with the old Control Board and I need to also replace it? please help!
jeffrey_benjamin (Refrigerator & Freezer Repair)
by jeffrey_benjamin 15 years ago
jeffrey_benjamin (Washer Repair)
