barko4
#1 Posted : Friday, June 13, 2014 3:47:05 PM(UTC)
barko4
Ice maker is not making ice. I unplugged it and plugged it back in and it worked for a few days and stopped making ice again. After unplugging again it still doesn't make ice. Where do I start troubleshooting? The ice maker is in the "on" position.
barko4
#2 Posted : Wednesday, June 18, 2014 9:53:15 AM(UTC)
barko4
Update: The ice maker mechanism still works, but no ice is being produced except for a small trivial amount. The temp is 5° and we are going to change the filter before going any further. Any help would be appreciated.
#3 Posted : Friday, June 20, 2014 3:48:17 AM(UTC)
Also try dropping your freezer temperature to 0 degrees F.
barko4
#4 Posted : Friday, June 20, 2014 9:11:12 AM(UTC)
barko4
Ok, will give it a shot...
barko4
#5 Posted : Sunday, June 22, 2014 5:03:36 PM(UTC)
barko4
New water filter fixed the problem. Thanks for the help!
#6 Posted : Monday, June 23, 2014 1:46:42 AM(UTC)
You are welcome though I was barking up the wrong tree.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
whirlpool refrigerator side by side icemaker makes little or no ice (Refrigerator & Freezer Repair)
by T-ROY 11/6/2008 2:59:14 PM(UTC)
