Mlesch
#1 Posted : Wednesday, June 18, 2014 8:19:03 PM(UTC)
Mlesch
I hope this question has not been asked, I have searched and I can not find anything similar.
I bought this chest freezer used and it will not get cold, when I plug it in it "turns on" but I don't think it is fully turning on, it is super quiet kinda like the compressor is turning on but not fully, if that makes since. After I run it for a bit I do hear some fluid moving sounds so I assume it is working enough to condense the freon. I have also tried bypassing the thermostat, and that didn't make any difference, turned on but still not "fully". It doesn't get even a little bit cold, I don't know where the condenser or evaporator is, I assume they are embedded in interior and exterior skin? And the compressor is the big round black thing in the bottom right? I can take some pictures if it would help.
#2 Posted : Thursday, June 19, 2014 2:30:53 AM(UTC)
If the compressor is hot and vibrating. you have serious system problems. Probably not worth fixing.
Mlesch
#3 Posted : Thursday, June 19, 2014 5:48:52 AM(UTC)
Mlesch
The compressor is getting hot and vibrating, figured that was normal, what is wrong with it?
#4 Posted : Thursday, June 19, 2014 9:10:53 AM(UTC)
You probably have an evaporator leak and damaged compressor, assuming an R134A system.
