tine78
#1 Posted : Tuesday, June 17, 2014 1:13:46 PM(UTC)
tine78
on spin cyclethe Barrel isnt spinning. the washer drains just doesn't spin. Held doent he lid switch and can hear the motor running but no spinning. replace the coupler and still didn't fix the problem. any suggestions
AllAroundAppliance
#2 Posted : Tuesday, June 17, 2014 4:16:47 PM(UTC)
AllAroundAppliance
Hello, thank you for asking your question here.
If you hold down the lid switch and turn the drum, does the drum start to spin?
Appliance Repair Portland
tine78
#3 Posted : Tuesday, June 17, 2014 4:25:44 PM(UTC)
tine78
No it doesn't. It will spin from spinning it and the stop.
AllAroundAppliance
#4 Posted : Tuesday, June 17, 2014 4:45:27 PM(UTC)
AllAroundAppliance
The motor is running while you are turning it by hand right? Do you notice any oil under the unit?
tine78
#5 Posted : Tuesday, June 17, 2014 4:52:19 PM(UTC)
tine78
No, no oil.
AllAroundAppliance
#6 Posted : Tuesday, June 17, 2014 5:32:15 PM(UTC)
AllAroundAppliance
In your original post you said when you hold the lid switch down in the spin part of the cycle you can hear the motor running? Now you don't hear the motor running?
tine78
#7 Posted : Tuesday, June 17, 2014 5:36:07 PM(UTC)
tine78
No I can hear the motor running. It sounds like it's spinning but it's not I tired turning tbe barrel and it spun for a second and slows to a stop.
AllAroundAppliance
#8 Posted : Tuesday, June 17, 2014 5:47:27 PM(UTC)
AllAroundAppliance
Alright that's what I needed to know. Just wanted to make sure before I gave you an answer.
The basket drive is bad. It comes with the clutch. You can replace just the clutch if there is no oil on the clutch. 99% of the time when this happens the basket drive goes bad and leaks oil down onto the clutch that's why you replace both. You can buy the basket drive with the clutch assembly. See link below.
Basket Drive & Clutch Link
CrossWashappliances
#9 Posted : Wednesday, June 18, 2014 7:06:19 PM(UTC)
CrossWashappliances
I would just replace the clutch to start. Whenever a washer doesnt spin but I know the coupler is good and the motor and transmission are good, its always the clutch. A new clutch should fix it
Guest (4)
