kbeealexander
#1 Posted : Saturday, June 7, 2014 5:59:58 AM(UTC)
kbeealexander
Our dryer's start button does not work. When the timer is set we can hear it clicking, however when we push the button nothing happens, no click, no hum, just nothing.
Thank you
#2 Posted : Tuesday, June 10, 2014 3:07:05 AM(UTC)
Your model number does not look complete.
Sears/Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
Could be that you have blown the thermal fuse.
This is often on the blower assembly.
Unplug the unit and if your unit has a fuse check it with a meter.
If it is blown be sure to check/clean your vent system before replacing it as this is the most common cause of it blowing.
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
dryer not starting (Dryer Repair)
by DConway0005 3/16/2017 3:40:22 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by Matt18 11/26/2013 9:56:49 AM(UTC)
by rberger3 10/23/2013 7:34:39 PM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
by Rogscott 4/13/2012 4:34:09 PM(UTC)
