I own a Whirlpool Gold Series double door refrigerator. It cools food contents well but the motor keep running continuously. This is what happens: the motor stops and restarts immediately barely a second later. Then half a minute later the same happens, the motor stops and restarts immediately. I vacuumed the cooling coils at the bottom of the frodge because they were full of dust but it did not stop the issue. I power cycled the fridge once but the problem remained.
Turn the cold control up all the way, if it runs all the time, you probably have a bad cold control.
Hi Yes i turned the freezer temperature all the way up from zero to 6 Fahrenheit and the motor finally stopped. I then went backward to 1 and waited.after 20 mins or so the motor resumed and never stopped until i pushed the control back up to 6. Then i left it at 6 degrees. I waited about 30 mins and sure enough the motor resumed and it does not stop, it goes for 3 mins, stops for a fraction of a second, resumes immediately. It does this indefinitely.
With the cold control turned up, measure the freezer temperature.
HI With the cold control turned up to 6F the freezer temperature reads 8F.
Seems like you have an overheating compressor, or a compressor failing possibly from refrigerant contamination.
Well thanks for this diagnosis, this is really helpful. I wonder how much it would cost to repair... does not sound good
