Misterbean
#1 Posted : Tuesday, May 6, 2014 1:44:40 PM(UTC)
Misterbean
I own a Whirlpool Gold Series double door refrigerator.
It cools food contents well but the motor keep running continuously.
This is what happens: the motor stops and restarts immediately barely a second later. Then half a minute later the same happens, the motor stops and restarts immediately.
I vacuumed the cooling coils at the bottom of the frodge because they were full of dust but it did not stop the issue.
I power cycled the fridge once but the problem remained.
#2 Posted : Wednesday, May 7, 2014 3:35:23 AM(UTC)
Turn the cold control up all the way, if it runs all the time, you probably have a bad cold control.
Misterbean
#3 Posted : Wednesday, May 14, 2014 2:28:41 PM(UTC)
Misterbean
Hi
Yes i turned the freezer temperature all the way up from zero to 6 Fahrenheit and the motor finally stopped. I then went backward to 1 and waited.after 20 mins or so the motor resumed and never stopped until i pushed the control back up to 6. Then i left it at 6 degrees. I waited about 30 mins and sure enough the motor resumed and it does not stop, it goes for 3 mins, stops for a fraction of a second, resumes immediately. It does this indefinitely.
#4 Posted : Thursday, May 15, 2014 1:45:33 AM(UTC)
With the cold control turned up, measure the freezer temperature.
Misterbean
#5 Posted : Friday, May 16, 2014 5:54:31 AM(UTC)
Misterbean
HI
With the cold control turned up to 6F the freezer temperature reads 8F.
#6 Posted : Friday, May 16, 2014 7:42:23 AM(UTC)
Seems like you have an overheating compressor, or a compressor failing possibly from refrigerant contamination.
Misterbean
#7 Posted : Friday, May 16, 2014 11:46:05 AM(UTC)
Misterbean
Well thanks for this diagnosis, this is really helpful. I wonder how much it would cost to repair... does not sound good
RCA Fridge Runs Continuously (Refrigerator & Freezer Repair)
by Bigfoot100 6/17/2010 7:10:02 PM(UTC)
