P2XUB
#1 Posted : Tuesday, May 13, 2014 12:59:16 AM(UTC)
P2XUB
At the end of cycles water drains...tub and agitator spin simultaneously. When coming to a stop the clutch releases and tub spins freely and agitator stops then clunking/banging starts. It is in time with the speed of the tub. Stops when tub stops spinning. Ideas?
sidfink43
#2 Posted : Wednesday, May 14, 2014 7:38:41 AM(UTC)
sidfink43
Check the Sticky on Direct Drive Brakes at the top of the washer page. It sounds like your brakes are not engaging.
