coachpelkey
#1 Posted : 11 years ago
coachpelkey
I have an electric range Pro Line Series.
About 3 days ago I went to turn on the knob to boil some water and all 4 burners are not working, no light on no nothing.
The stove works ok, all the displays are working ok.
Any suggestions?
The stove itself is hard wired into the circuit box, the landlord ran it straight down to the box. Should I try and turn it off for a few minutes and turn it back on?
The knobs were touchy in the past, any nudge against them, turned the burner on.
Any help would be appreciated.
ryanpelkey@gmail.com
Thanks in advance.
sookeslayer
#2 Posted : 11 years ago
sookeslayer
From the sounds of it the breakers for the elements is tripped. Do you have a stove fuse panel at the top of your burners (at the back). Each element is protected by fuses and these should be checked.
