As the title says, not heating. I have replaced everything, fuse, heating element, and all the other thermostats, good continuity. Still not heating. Any ideas?
Groups: Expert
Timers on these models are cheap and a common failure item but first check for 240vac at terminal block. Try resetting panel breaker first. If that doesn't do it, unplug dryer, remove the small cover on rear to expose terminal block. Check that terminals are tight and there is no burning/melting of any wires there. Plug dryer back in and check for 240vac across outer terminals. If good, replace timer. Problem could also be a bad motor switch but more likely the timer. Whirlpool W10185970 Timer - AppliancePartsPros.comEric
