csdcj107
#1 Posted : Sunday, April 13, 2014 2:47:37 PM(UTC)
csdcj107
Replaced Thermal Fuse, Hi Limit Thermostat, Thermostat 4 Wire And Start Switch. Still Won't Start!
#2 Posted : Monday, April 14, 2014 2:34:16 AM(UTC)
Parts for Whirlpool WED5320SQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Have you checked the power?
L1 to Neutral has to be about 120 volts.
If power is good then try tracing the motor/start circuit.
Unplug the unit.
Set the unit at mid cycle timed dry where it will not start.
Attach (clip or tape) one meter lead to the L1 prong on the line cord and leave it there.
L1 (black) at the terminal strip should be 0 ohms.
BL and Bu at the timer should be 0 ohms.
Both sides of the thermal fuse should be 0ohms.
4M at the motor should be 0 ohms.
5M at the motor should be a around 1 ohms (motor windings)
The the push to start switch activated both sides of the switch should be about an ohms.
Keep the start switch activated.
With the door switch closed CO and COM should be about one ohm.
With door closed Neutral (white) at the terminal strip should be about an ohm.
Also the Neutral prong on the line cord should be about an ohm.
You should find the problem as that is the start circuit checked out.
I am assuming that the unit seems dead and does not make any noise when you try to start it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
WED5320.pdf (266kb) downloaded 3 time(s).
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
