rhesusmonkeyboy
#1 Posted : Friday, April 11, 2014 2:40:47 PM(UTC)
rhesusmonkeyboy
Hello.
So what has 2 thumbs and closed the garage door on his dryer door?
This guy.
Anyways, the door "closes" but not fully, so the dryer thinks it's open. I used duct tape and the dryer works fine.
I can wiggle the door super duper just barely up and down, if not for what just happened, I would think that this is how the door always behaved.
I suspect I just need to "tighten it up" some, but would like to check with y'all. I tried tightening one of the screws on the chassis, but I am not strong enough.
Again. Dryer door was open ... garage door button was pushed ... good news is that it didn't close, but dryer doesn't work without duct tape ( yep, the light on the dryer is on without the tape ) ...
Thanks!
~Rhesus
PS Good news is that the garage appears to be totally fine ... the whole house is 5 years old.
#2 Posted : Saturday, April 12, 2014 1:12:39 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
rhesusmonkeyboy
#3 Posted : Saturday, April 12, 2014 6:54:17 AM(UTC)
rhesusmonkeyboy
DLG5966W front loader.
Just my pinky can push it sufficiently to turn off the light.
I can't edit my post, should I delete and repost?
#4 Posted : Saturday, April 12, 2014 10:08:07 AM(UTC)
Parts for LG DLG5966W / ABWEEUS Dryer - AppliancePartsPros.com
Check the latch (item A320) and the latch hook (item A410) in section 2 of the parts.
Clicking on the part's description or picture will open a new page with more info about it
