Ktaka23
#1 Posted : Wednesday, April 9, 2014 9:11:11 AM(UTC)
Ktaka23
the washer works great in agitate mode then drains water but will not fill with water in order to rinse. The tub just sits there with no water...then there is smoke coming from the behind the washer and a burning smell. Please help.
sidfink43
#2 Posted : Thursday, April 10, 2014 4:37:11 PM(UTC)
sidfink43
Okay this is somewhat of a mystery since first of all it works through the wash cycle which suggests that there is nothing mechanically wrong with the machine, and second, all that has to happen is for the inlet valve to open to let cold water in to rinse.
If you are using only hot water for wash, try a wash cycle on the cold water and see if it fills. If it does not and you get the smoke and burning smell the problem could be in the inlet valve assembly or the timer, but most likely the valve assembly. To test, hook up the cold water connectors at the valve assembly to the hot water and see if it fills on cold water wash. If so that wold confirm the valve assembly as the problem. If not, the timer is likely the issue.
ge washer will not rinse or spin (Washer Repair)
by tmm313psu 10/2/2009 3:48:31 PM(UTC)
by jimbo0555 6/26/2009 5:20:11 PM(UTC)
