EricT
#1 Posted : Thursday, December 13, 2007 2:23:17 PM(UTC)
EricT
How do you take apart panel to put new one in?
#2 Posted : Friday, December 14, 2007 12:42:30 PM(UTC)
Open the lower oven door and remove the screw on each side of the side trim. Pull the bottom of the side trim toward yourself and down to release it from the control panel tab.
Remove the screw on each side of the control panel. Pull the bottom of the control panel toward yourself and up to release the upper tabs.
- Here are the break down diagrams for the Whirlpool oven Model RBD305PDB13
EricT
#3 Posted : Friday, December 14, 2007 2:45:51 PM(UTC)
EricT
Great that worked.
I was getting F2 E6 error replaced touch key and checked ribbon cable its ok but still not fixed I am replacing computer control board next. Any thoughts ? This is what the paper documentation from whirpool says to do that I found in top of oven.
#4 Posted : Friday, December 14, 2007 2:59:14 PM(UTC)
Yes, if you already replaced the key pad and it did not help, per the Whirlpool technical sheets, the control board has to be replaced either.
Guest (4)
