jdavey26
#1 Posted : Sunday, March 30, 2014 7:31:53 AM(UTC)
jdavey26
My dishwasher takes and extra 85 minutes for a normal wash cycle for a total of almost 3 hours. The heating element does not heat. I checked the element and the high temp thermostat and they have the correct resistance and continuity. Could a bad thermistor 8269208 cause the heating element not heat? What else could be the cause?
#2 Posted : Monday, March 31, 2014 5:06:27 AM(UTC)
Parts for Kenmore Dishwasher 66516914001 - AppliancePartsPros.com
Yes a bad thermistor could cause your problem, so I would check it.
You checked the heater and the hi-limit, did ypou check them in series at the control board just to be sure that the wiring to them is also OK.
If OK and the thermistor is OK then I would say that the control board is toast.
Could be just the heater relay on the board but this is difficult to troubleshoot.
File Attachment(s):
16914001.pdf (172kb) downloaded 4 time(s).
jdavey26
#3 Posted : Monday, March 31, 2014 6:09:23 AM(UTC)
jdavey26
Originally Posted by: denman Go to Quoted Post
How do you get to the control board? Do you have to remove the complete stainless steel panel on the inside of the door?
#4 Posted : Monday, March 31, 2014 9:58:40 AM(UTC)
I am not sure as I cannot find a parts break down for this unit.
It is actually made by Whirlpool.
When I look up the control board I see it is also used on a Whirlpool Voyager.
Below is a link to a manual for that model, hopefully they are put together the same. You will have to join the site and be logged in to download the manual.
http://appliancejunk.com...wnloads;sa=view;down=233
